Upgrading Axure RP 9 Team Projects to RP 10
If you have team projects that you created with Axure RP 9, you can upgrade them to Axure RP 10 by following the steps below.
If you're upgrading from a version of Axure RP 8 or earlier, follow the steps in this guide first.
Upgrading Team Projects from Axure RP 9 to Axure RP 10
Ask all collaborators to check in their changes to the project by going to Team → Check In Everything in the previous version of Axure RP. Check in your changes as well.
Still in the previous version of Axure RP, go to Team → Get All Changes from Team Directory, and then save and close your local copy.
Open your local copy with Axure RP 10, and then follow the steps in the Upgrade Wizard.
Once you’ve upgraded the team project, collaborators can either open their current local copy in Axure RP 10, or they can get a new local copy of the team project in Axure RP 10 by going to Team → Get and Open Team Project.
Troubleshooting Upgrade Conflicts
If you encounter any conflicts during the upgrade process, or if you need to revert the team project back to Axure RP 9 for any reason, follow these steps:
Log in to app.axure.cloud or the Axure Cloud desktop app.
Select the workspace the team project is located in and then click on the project's name.
At the top of the the project overview page, switch to the History tab.
Locate the revision that states Upgraded project to Axure RP 10 and then click the Revert Upgrade - Return to RP 9 link.
On the next page, select the Revert to RP 9 button to confirm.
Reverting a team project will restore it to the last version from Axure RP 9, and all versions from Axure RP 10 and their check-in history will be lost.
For more information on team project revision history, head over to the Team Project History page.
