List of events
Page and components events list​
Mouse​
  • Page click or tap: When the page is clicked or tapped
  • Page double click or double tap: When the page is double-clicked or double-tapped
  • Page context menu (right click): When the context menu is triggered on the page, either by right-clicking or another method
  • Page mouse move: Fires continuously as the mouse cursor is moved around the page
Keyboard​
  • Page key down: When a keyboard key is pressed
  • Page key up: When a keyboard key is released (after being pressed)
Page​
  • Window resized: When the browser window is resized (also fires when the page first loads, after Page loaded)
  • Page loaded: When the page first loads in the web browser
  • Adaptive view changed: When the current adaptive view changes due to one of the following:
    • the browser window is resized
    • the view is set with the Set adaptive view action
    • a new view is selected in the Adaptive views dropdown in the prototype player
  • Window scrolled up: When the page is scrolled up
  • Window scrolled down: When the page is scrolled down
  • Window scrolled: When the page is scrolled in any direction
  • Variable changed: When the value of the global variable is updated by an interaction
Widget events list​
All widgets​
Mouse​
  • Click or tap: When the widget is clicked or tapped
  • Double click or double tap: When the widget is double-clicked or double-tapped
  • Context menu (right click): When the context menu is triggered on the widget, either by right-clicking or another method
  • Mouse button down: When the widget is clicked, while the mouse button is pressed down
  • Mouse button up: When the widget is clicked, upon the mouse button being released
  • Mouse move: Fires continuously as the mouse cursor is moved over the widget
  • Mouse enter: When the mouse cursor enters the area over the widget
  • Mouse exit: When the mouse cursor exits the area over the widget
  • Mouse hover: When the mouse cursor hovers over the widget for one second
  • Long click: When the mouse button is held down on the widget for one second
Keyboard​
  • Key down: When a keyboard key is pressed while the widget has browser focus
  • Key up: When a keyboard key is released (after being pressed down) while the widget has browser focus
Widget​
  • Moved: When the widget is moved by a Move action
  • Rotated: When the widget is rotated by a Rotate action
  • Resized: When the widget's size is changed by a Set size action
  • Shown: When the widget is shown by a Show or Toggle visibility action
  • Hidden: When the widget is hidden by a Hide or Toggle visibility action
  • Got focus: When the widget gets browser focus by being clicked or tabbed to, or via a Focus action
  • Lost focus: When the widget loses browser focus by being clicked or tabbed away from, or via a Focus action
  • Selected: When the widget is set to its selected state with a Set selected action or when a checkbox or radio button is clicked
  • Unselected: When the widget is set to its unselected state with a Set selected action or when a checkbox or radio button is clicked
  • Selected or unselected: When the widget's selected state changes due to a Set selected action or when a checkbox or radio button is clicked
  • Loaded: When the widget initially loads in the web browser (fires after Page Loaded)
Droplists and list boxes only​
  • Selection changed: When the selected option in the droplist or list box changes
Text fields and text areas only​
  • Text changed: When the text on the text field or text area changes, either by a user typing in it or via the Set text action
Dynamic panels only​
Gesture​
  • Swiped left: When the dynamic panel is swiped from right to left
  • Swiped right: When the dynamic panel is swiped from left to right
  • Swiped up: When the dynamic panel is swiped from bottom to top
  • Swiped down: When the dynamic panel is swiped from top to bottom
Dynamic panel​
  • Panel state changed: When the dynamic panel's state is changed with the Set panel state action
  • Drag started: When you begin to drag the dynamic panel
  • Drag dropped: When you stop dragging the dynamic panel (fires when the mouse button is released, not when it stops moving)
  • Dragged: Fires continuously while the dynamic panel is being dragged
  • Scrolled up: When the dynamic panel is scrolled up
  • Scrolled down: When the dynamic panel is scrolled down
  • Scrolled: When the dynamic panel is scrolled in any direction
Repeaters only​
  • Item loaded: When the repeater's items first load in the web browser and when the repeater's dataset changes in any way
  • Item resized: When a repeater item's size changes as a result of any interaction (such as a widget in the item being shown, hidden, or resized)
