List of actions
Open link: Opens a prototype page or external URL in one of the following locations:
  • Current window: the current browser window
  • New window/tab: a new browser window or tab
  • Popup window: a popup window
  • Parent window: the parent window of a popup window (this must be used from a page loaded in a popup window)
Close window: Closes the current browser window or tab
Open link in frame: Changes the page loaded in an inline frame widget or the page containing an inline frame
  • Inline frame: and inline frame on the page
  • Parent frame: the page containing an inline frame (this must be used from a page loaded in an inline frame)
Scroll to widget (anchor link): Scrolls the browser window to the location of a widget on the page
Widgets​
Show/hide: Changes the visibility of a widget
Set panel state: Changes the visible state of a dynamic panel
Set text: Changes the text on a widget
The Rich text option allows you to format the new text however you'd like.
Set image: Changes the image on an image widget
Set selected/checked: Changes a widget's selected/checked state. This changes the widget's visual appearance if it has a Selected style effect
Set selected list option: Changes the selected list option of a droplist or list box
Set error state: Changes a widget’s error state. This changes the widget's visual appearance if it has a Error style effect
Enable/disable: Enables or disables a widget. A disabled widget cannot be interacted with in the web browser, and its visual appearance changes if it has a Disabled style effect
Move: Moves a widget to a new location on the page
Rotate: Rotates a widget around a chosen anchor point
Set size: Changes the size of a widget
Bring to front/back: Brings a widget to either the frontmost or backmost layer in the depth order (z-index) of the page
Apply style: Applies a saved style or specific style properties to a widget
Set opacity: Changes a widget's opacity
Focus: Gives a widget browser focus, moving the text cursor onto text-input widgets and highlighting clickable widgets
Expand/collapse tree node: Expands or collapses the selected nodes of a tree widget
Variables​
Set variable value: Sets the value of a global variable
Repeaters​
Add sort: Sort a repeater dataset using the specified sort criteria
Remove sort: Removes sorting from a repeater
Add filter: Filters a repeater dataset using the specified filter criteria
Remove filter: Removes filtering from a repeater
Set current page: Shows a specific page of a paginated repeater
Set items per page: Sets the number of items displayed per page of a paginated repeater
Datasets → Add rows: Add new rows to a repeater's dataset
Datasets → Mark rows: Marks the rows in a repeater's dataset that meet specified criteria
Datasets → Unmark rows: Unmarks the rows in a repeater's dataset that meet specified criteria
Datasets → Update rows: Updates the existing data in a repeater's dataset
Datasets → Delete rows: Deletes rows from a repeater's dataset
Miscellaneous​
Set adaptive View: Changes the adaptive view displayed in the web browser
Wait: Adds a pause of the designated amount of time, in milliseconds, before any subsequent actions are executed
Other: Shows a specified text description (as a placeholder for an action that has not been prototyped)
Fire event: Fires a specified event on a page, component, or widget
Raise event: "Raises" an event on a widget in a component up to the page level
