Sharing Axure RP Projects from Axure Cloud
To quickly learn the basics of sharing your Axure RP prototypes, check out the Sharing Your Prototypes module of our Core Training series.
When you publish an Axure RP file to Axure Cloud, you're given a publicly shareable link to the file's generated HTML. You can view this link at any time in the Publish → Publish to Axure Cloud menu in Axure RP and in your list of projects at app.axure.cloud.
You can send this link to anyone to allow them to view the project's HTML.
The public link allows people to view and comment on the project's HTML but not to edit, download, or Inspect the project's source RP file. To grant teammates those privileges, add them to the project's workspace.
Project Access Code
When publishing an Axure RP file to Axure Cloud, you have the option to set an access code for the project, which protects the project's public link.
You can also add or edit a project access code in Axure Cloud by navigating to the project Overview page. From there, click the Share button at the top of the right-side panel. Then in the dialog that appears, click the Not Set link under the Access Code header.
Pretty URLs
Pretty URLs allow you to customize and simplify the URL for specific pages, so that a URL leading to a specific project page will end with "/my-url" or "my-section/my-url" instead of ending with “.html”. Once you open a project’s overview page in Axure Cloud, you can select the Advanced tab to find options for adding in plugins, pretty URLs, and redirects.
To assign a pretty URL to a page, scroll down to the list of the project pages, and then select the Edit button in the row of the specific page that you would like to assign a pretty URL to.
Then in the dialog that appears, you can assign the pretty URL, as well as add a custom page title and a meta description.
Custom Page Title: Type in your custom page title. For SEO purposes, we suggest using keywords at the beginning of the page title and your business name at the end.
Pretty URL: Type in the URL, include the folder structure as appropriate.
Meta Description: Type in the meta description. Keep in mind this is the text description that shows in search results. This should be a summary of what the page is about. Make sure to include relevant keywords.
Default Page
You can also select a default page that is displayed instead of start.html. You can do this by opening the project URL by clicking the Assign button in the Default Page box. Then in the dialog that appears, make a selection from the dropdown list of page names from your project, and click the Set as Default button.
If you later wish to remove the default page (or assign a new page as the default), click the Clear button. To get the sitemap to show, add /start.html#p= or /index.html#p= to the end of the URL.
Custom 404 Page
The custom 404 page will display if a user reaches a URL which is not in your sitemap. Assign a custom 404 page by clicking the Assign button, selecting the page from the dropdown list, and clicking the Set as 404 button. If you later wish to choose a different 404 page (or assign a new 404 page), click the Clear button.
Redirects
Redirects are also found in the Advanced tab, and can be used to point old page URLs to new ones. For example, to make "home" go to "new-home", create a redirect with an incoming URL of "home" and redirect to "new-home". If you're not using pretty URLs, you can make "home.html" go to "new-home.html" similarly.
You can also make an entire path redirect to one page. For example, to make any page within the "my-section/" path redirect to the "my-new-section" page, create a redirect with an Incoming URL of "my-section/*" and Redirect To "my-new-section".
Disabling the Public Link
You can disable a project's public link on the project's Overview screen at app.axure.cloud. Click Share next to the public link at the far right of the page, and then toggle the Enable Share Link button in the dialog that appears.
When a project's public link is disabled, the project can only be viewed by teammates you have added to the project's workspace. (You can enable the link again later in this same dialog if needed.)
