›The Basics
The Basics
  • Interactive Button
  • Hiding and Showing Widgets
  • Pass Text to Next Page
  • Anchor Link
  • Embedding Media
  • Full Width Image or Banner
  • Scrolling Region
  • Navigation Menu
  • Tab Menu
  • Accordion Menu
  • Drag and Drop
Complex Interactions
  • Account Login
  • Auto Tab Fields
  • Blinking Text
  • Set Text with Droplist
  • Slider Control
  • Terms and Conditions
  • Timer
Mobile Patterns
  • Swiping Slideshow
  • Toggle Switch
Scrolling Region Tutorial
In this tutorial, you'll learn how to use a dynamic panel to make a region of the page that scrolls independently of the rest of your design.
  2. Drag a heading 1 widget onto the canvas from the Libraries pane.
  3. Place an image widget and three paragraph widgets in a column below the heading.
2. Place the Widgets in a Scrollable Dynamic Panel
  1. Select all the widgets on the canvas.
  2. Right-click the selection and select Create Dynamic Panel in the context menu.
  1. Set the new dynamic panel's height to 300, which will cut off some of the paragraph widgets.
  2. In the Dynamic Panel section of the Style pane, select Scroll Vertical in the scrolling dropdown.
3. Preview the Page
Preview the page and scroll the dynamic panel up and down.
Scrollable Table with Fixed Header
You can use a scrollable dynamic panel to create a scrollable table with a fixed header. Create your table header out of rectangle widgets and place the table widget below them. Then, place the table in a scrollable dynamic panel and shorten the panel so that only a few rows of the table are visible. Scrolling the dynamic panel will give the appearance of scrolling table rows with a fixed header.
← Full Width Image or BannerRotating Carousel / Slideshow →
  • 2. Place the Widgets in a Scrollable Dynamic Panel
  • 3. Preview the Page
    • Scrollable Table with Fixed Header
